rough alignment
Old Oct 16, 2008 | 03:39 PM
bcartman2's Avatar
bcartman2
Default rough alignment
i just replaced my right front lower control arm before i drive it to the alignment shop i want to get it close so that i have any problems on my way there. how do i do a rough alignment without a rack?
Old Oct 16, 2008 | 04:49 PM
DeltaBravo's Avatar
DeltaBravo
I would think that if you put it back together the way it came apart, with all the spacers, etc., where they were originally, you should be fine for a short distance. I can't imagine that it would be that far off. I could be wrong, tho, so hopefully someone else can chime in with the correct info if I am.
Old Oct 16, 2008 | 05:03 PM
bcartman2's Avatar
bcartman2
my biggest worry is the eccentric bolt setup, there is about 3/4 of an inch play in them, so i could be up to an inch and a half off.
Old Oct 16, 2008 | 09:38 PM
bcartman2's Avatar
bcartman2
TTT.......anyone
Old Oct 16, 2008 | 10:33 PM
FRCTony's Avatar
FRCTony
Eccentrics should be about the same position as the other side. Just match it up.
You could put a level against the wheel and set it close enough to 0* camber, might get a pull from incorrect caster, but it wont eat the tires.
Next time take note of the eccentrics before you tear it apart
To rough alignment
