hey vet buddies my fog lights are not coming on when i press the button.
i check the main fuse it is good. they only come on with my alarm.
also the yellow light where the button is, by the trunk release is not on.
thanks
Is the fog lamp switch light coming on? If so, its probably not the fuse and not the relay. The tiny indicator lamp gets its power from the output of the relay when its engaged. If the light is coming on, check the ground pack on the right forward frame rail adjacent to the hood riser.
is the fog lamp switch light coming on? If so, its probably not the fuse and not the relay. The tiny indicator lamp gets its power from the output of the relay when its engaged. If the light is coming on, check the ground pack on the right forward frame rail adjacent to the hood riser.
yes the fog lamp switch is lighting up along with the trunk release button. But that yellow light is not on.
