Comp mode and Oil Temp Display?
Old Jan 10, 2002 | 10:11 PM
rjn's Avatar
rjn
Default Comp mode and Oil Temp Display?
Is it possible to get the Oil temperature display on the DIC when in competition mode or with active handling off?
I'd like to monitor my oil temperature while on the road course, and I typically run with TC/AH disabled.
Thanks in advance,
Rob
01z06
Old Jan 10, 2002 | 10:13 PM
chocoholic's Avatar
chocoholic
Default Re: Comp mode and Oil Temp Display? (rjn)
Tried pressing "reset"?
Old Jan 10, 2002 | 10:27 PM
rjn's Avatar
rjn
Default Re: Comp mode and Oil Temp Display? (chocoholic)
I thought so....I pressed about every other button, including "GAGES" (jeez that spelling drives me nuts!), to get the oil guage back, and it didn't do a thing.
If it's really as simple as that, I'll be happily schooled...
Old Jan 10, 2002 | 10:36 PM
chocoholic's Avatar
chocoholic
That's probably it, then. :)
Once you "acknowledge" the message via "reset" you can then operate the DIC as before. It seems odd at first then it makes sense after a while.
Old Jan 10, 2002 | 10:53 PM
rjn's Avatar
rjn
Choc,
Thanks! The info's value will last a lot longer than my embarassment... :cheers:
Rob
Old Jan 11, 2002 | 03:36 AM
Mike Schriber's Avatar
Mike Schriber
Reset will do the trick.
You should take a look at our TracActive Controller. It'll automatically put the car in Competition Mode when you start the engine (or turn off TC/AH if you'd like). The Deluxe model even clears the DIC for you!
For more info, click the banner below. The LAPD is running a special with free shipping through their Corvette Forum Mall store right now.
Mike :flag
Old Jan 11, 2002 | 12:58 PM
davidmax's Avatar
davidmax
I've never had to rest my DIC and I also drive with no A.H ,comp mode or traction control. David S.
To Comp mode and Oil Temp Display?
