I was reading through some old posts about clutch balancing doing some research before I posted, I have an issue I swapped in a LS6 clutch PP hydralicis and flywheel in my 99, I did take the old and new setup to have a shop balance the clutch and flywheel, my issue is that I seem to have some vibration that starts at about 2000 RPM its not that bad but its there. Also a little vibration just sitting in neutral as well. Upon reinstall I had to kind of guess the exact loaction of the flywheel becuase like a Dummazz I didnt mark it, could this be part of my vibration problem since the new might not be in the exact location as the old??
Rich
Rich
No, GM was smart and offset the bolts so it can only go on one way. Did you purchase a whole LS6 clutch setup from GM with a new clutch disc, PP, and flywheel?
No purchased from a guy wo pulled it of is Z06 @ 3000 miles and had been sitting in his garage it still looked almost new,.... tons of life left on the parts he went with a different setup couldnt pass on the deal
