Turn Signels and Flashers
Old Oct 21, 2008 | 11:31 PM
smace's Avatar
smace
Default Turn Signels and Flashers
I am having a issue with the turn signals and flashers. Sometimes they will work and smetimes I get nothing. Any idea where to start. We they are not working I don't even get a light. When they want to work they work perfect.
Old Nov 15, 2008 | 12:08 AM
PowerMad's Avatar
PowerMad
I have the same problem. It is very confusing. Nobody seems to have a clue. The strange part is I can turn them off, wait a few seconds, then turn them on again... they may or may not work.
Old Nov 15, 2008 | 01:26 AM
Kobie's Avatar
Kobie
St. Jude Donor '19
Your turn signals run thru your hazard switch,You need to replace hazard switch.It will cost about $40.00 and take around a hour to do.At the top of the page is the ultimate DIY page,Thats were you"ll find the directions.Good luck!
Old Nov 15, 2008 | 08:13 AM
rws.1's Avatar
rws.1
here is a link to the simplified approach DIY..
the othe rone invilved removing the dash pad...
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
Old Nov 15, 2008 | 09:25 AM
KENCO's Avatar
KENCO
St. Jude Donor '11
You can push in and out repeatedly like a madman on the hazard button and it somewhat cleans the contacts and you will be good for awhile until you do the repair.
Old Nov 15, 2008 | 09:31 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
http://www.corvette-enhancements.com/c5_flasher_fix.php
Get this part from Richard and be done with the flasher module
To Turn Signels and Flashers
