Front turn signal not working
Old Oct 22, 2008 | 01:56 PM
Army08's Avatar
Army08
Default Front turn signal not working
My rears work but not the fronts. I have taken the bulbs, which are not burned up and are working, out and the filaments seem to be intact.
Is there a separate flasher for the front and rear? I have looked for the fuse but could not locate. I checked most all the fuses and they seem to be good. Can someone steer me in the right direction?
Old Oct 22, 2008 | 02:03 PM
lucky131969's Avatar
lucky131969
Do the DRL's work?
Old Oct 22, 2008 | 02:08 PM
Army08's Avatar
Army08
I just checked and apparently not. I never use them
Old Oct 22, 2008 | 02:12 PM
lucky131969
You don't have a choice, they come on automatically..controlled by the BCM. The DRL's ( Daytime running lights) on a C5 are the turn signals. So with the car running, both turn signals should be illuminated. If not, check Minifuse #2 (15 amp) in the underhood electrical center.
Old Oct 22, 2008 | 02:16 PM
Army08's Avatar
Army08
Thanks, I will check it
Old Oct 23, 2008 | 02:23 PM
lucky131969
Did you find the problem?
Old Oct 23, 2008 | 07:40 PM
Old Rotor Head's Avatar
Old Rotor Head
I've had to change both of my bulb sockets. Dealership sells for small fortune. Easy, socket and pigtail.
If you ain't Cav you ain't sh..
Old Oct 24, 2008 | 07:31 AM
rws.1's Avatar
rws.1
check the sockets they could be corroded.....
The bulb has a tendency to melt a hole in the housing and let in water which may blow the bulb and corrde the socket.
GM wants $70 for the socket/pigtail
cheapest place for AC/Delco original is Rock auto...
www.rockauto.com
To Front turn signal not working
