A4 shifter won't release from park
Old Oct 23, 2008 | 11:05 PM
CARMINEVETTE's Avatar
CARMINEVETTE
Default A4 shifter won't release from park
Jumped in my 98 A4 to go for a ride and the tranny shifter would not release from park. I pushed the release button many times, banged the button with my hand, moved the shift forward and backward and it still would not release. Finally after moving the shifter back and forth in park and banging on the shifter more thimes than I want to count. It finally released and I was able to move it into reverse. It didn't happen the rest of the day. I had my foot on the brake while I was trying to get the shifter out of park. Has any body experience this? If so what was the resolution?
Old Oct 23, 2008 | 11:09 PM
BowTieRocket's Avatar
BowTieRocket
Could be torque lock. If you press against a parking block, or park pointing down (or up) hill, the weight of the car can hold the parking pawl locked into the parking gear.
Always set your parking brake before you put the car in park, and don't release the parking brake until you are out of park and in gear. If it happens again, try rocking the car while trying to get it out of park.
Could be the release interlock from the brake pedal, but if there's much load on the parking pawl at all, you get the torque lock deal going.
Old Oct 23, 2008 | 11:14 PM
CARMINEVETTE
It was in the garage on a flat surface. This was the first time I experienced this problem.
Old Oct 23, 2008 | 11:19 PM
motogib1's Avatar
motogib1
There is a mechanical cable that connects the ignition switch to the shifter and a holding solenoid. The solenoid is controlled by a signal from the brake pedal; brake applied= no power= no solenoid = shifting allowed. The key in run mode allows the cable to move out and the shifter to come out of park if the brake is pressed; the key cannot be removed unless the shifter is placed in park. Check for any loose wiring connectors; did you disconnect something and forget to reconnect it?
Found this in a previous A4 shifter thread. Never had the problem but on the surface sounds like there is a solenoid which holds the shifter in place. If it is not working properly it would not allow you ti shift into gear. Just a thought I had.
Old Oct 24, 2008 | 07:06 PM
CARMINEVETTE
Thanks motogib1 for your response. Is there a written process to troubleshoot this issue?
Old Oct 24, 2008 | 09:21 PM
Purerock105's Avatar
Purerock105
Doubtful. You can just simply remove the solenoid. You can then take car out of Park without having to depress the brake pedal. Its what I did. It seems to happen with big temp changes as well. The solenoid is located in the shifter housing and somewhat cumbersome to get to.
Old Oct 24, 2008 | 09:56 PM
CARMINEVETTE
Purerock105 thanks for your input. I did as you suggested and disconnected the solenoid. It was too difficult to remove the solenod so I just disconnected it from the shift linkage. Thanks again for the responses. As has been said before, the forum is a great source for help from a group of very knowledgeable people. Thanks!!
Old Oct 26, 2008 | 11:14 PM
Purerock105
Old Jun 17, 2009 | 06:46 PM
msu-dawg's Avatar
msu-dawg
Sounds like the problem I'm having- and a problem that seems to be getting more frequent at that. Is there a write-up somewhere on how to take the shifter housing apart to get to the solenoid in order to disconnect it?
am I understanding correctly that the cable that runs from the shifter up to the ignition area is only for the Ignition ON/Park interlock? Based on a different vehicle that I worked on previously I was assuming the "press brake" interlock would also be in that area but I guess I was assuming wrong.
thanks!
Old Jun 17, 2009 | 10:41 PM
Purerock105
You have to start with the center console glovebox and work northward towards the trim that surrounds the shifter, which of course is one piece as it becomes the radio/HVAC bezel as well.
Once you get enough removed to see what you are looking at. The solenoid looks like this. Simply remove the wires connected to it and remove it.
Old Jun 18, 2009 | 08:11 AM
msu-dawg's Avatar
msu-dawg
Thanks! I figured out yesterday that the shift lever boot just pulls up from around the shifter base, giving me access to the solenoid. Got it unplugged and no more problems.
Old Sep 16, 2009 | 06:52 PM
vett79's Avatar
vett79
OK it's starting to cool off and my shifter is starting to take it's time coming out of "PARK". It got real tough last winter.
Is there a way to disconnect this solenoid at the "other end" of the wire in question to save taking the shifter boot out. My confidence level of getting it back together is low.....
Thanks in advance
Old Sep 16, 2009 | 11:58 PM
Jeffwilson34's Avatar
Jeffwilson34
Check your brake light fuse.
The shifter will not release till the lights come on.
If the fuse blows the thing is stuck in park.
Old Sep 17, 2009 | 03:48 PM
vett79's Avatar
vett79
Brake lights are Ok. Shifter button just slow to activate. I just want to disconnect the solenoid (easily).
Old Sep 17, 2009 | 07:35 PM
bighank's Avatar
bighank
Default Don't remove the solenoid just disconnect the electrical connector
Had the same thing happen to me several times. I removed shift handle, loosened shift boot and saw the solenoid next to the shifter.
Simply UNPLUGGING the solenoid at the rear of the shift mechanism will do the trick. Been fixed for 2 years and its never going to lock out the shift lever again. BIGHANK
Old Sep 17, 2009 | 08:04 PM
vett79's Avatar
vett79
Big Hank........no need to take the whole console out? I know how to get the handle off. Once handle is off there's room to get your hand down inside the boot?
vett79
Old Sep 18, 2009 | 03:01 PM
vett79's Avatar
vett79
Nevermind......dumb a$$ attack. I did another search and found the Vette Essentials web site on how to get the boot out, I should have thought of their site as I used it for my seats.
Next project!
Old Sep 24, 2009 | 09:08 PM
Scotty3's Avatar
Scotty3
I had the same thing happen to me in my 98 A4. I removed the solenoid and it has been that way for 2 years now. The only way to get a new solenoid is to buy the whole shifter from GM.
To A4 shifter won't release from park
