light adjuster will not aim headlights
Old Oct 24, 2008 | 03:24 PM
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
Default light adjuster will not aim headlights
its me again
it seems as iv got the junkiest c5 on the forum but someone has to be it
i noticed at night my headlights were so lo that i over drove them
so i got out my trusty repair manual it said to turn the bottom adjuster to raisethe lights when i turned it nothing happned except the square
plastic in the light poped in and out of socket the light did not go up or down any help will be greatly appreciated
gorghamak
Old Oct 27, 2008 | 07:30 PM
aleadfoot's Avatar
aleadfoot
This is the worst part of the great C5 IMHO. I just been thru this dance of madness. The adjusters are junk. If you have figured out that the adjuster isnt moving and that you have pulled out the rod from the headlight get ready for some hassle. The rod that connects to the headlight is a bolt there is a torx screw on the top round part you need to while holding it with the right torx driver turn the adjuster rod and extend it out towards the front of the car it helps to lube the adjuster and the rod. When extended press it back into the headlight then you can slowly and carefully adjust but only so much or you will have to redo. Best of luck this is junk and should be recalled. If you break any of the parts a headlight assembly is the only way to acquire the parts dealers charge 750 each. I bought salvage yard parts and am all too familiar with your problem. Do not bend the rods. The short one on top is up and down the long rod is left to right. Best of luck
Old Oct 27, 2008 | 09:19 PM
rws.1's Avatar
rws.1
the 'golden rod" is soft metal and breaks easily
if you have not broke it or stripped it already try soaking for a few days with PB blaster.....
Old Oct 27, 2008 | 09:22 PM
rws.1's Avatar
rws.1
here is a thread that you MUST read...
http://forums.corvetteforum.com/show...t=golden%20rod
Old Oct 27, 2008 | 10:24 PM
gorghamak's Avatar
gorghamak
thanks for all the advice on the golden rods doesnt make me feel any beter but i know what im up against se ya all
Old Oct 27, 2008 | 10:30 PM
lucky131969's Avatar
lucky131969
Originally Posted by gorghamak
its me again
it seems as iv got the junkiest c5 on the forum...
The car is only as good as the person maintaining it. With a little TLC, you can bring her back to world class.
To light adjuster will not aim headlights
