Anyone have any thoughts using this cam on a H/C package?
I'm right in the ordering stage, but am having second thought about the cam I chose. I could use the Thunder Racing 220/220 114 cam, and Oliver used it in his, and really likes it. Of course it needs to pass CA smog, and the 216/216 cam works but not sure what the difference is between the cams in hp/tq and idle.
I need to decide by next week to finalize the deal.
BTW - MMS is doing the install *Stage II heads/headers/intake etc..
Without knowing the lift, I'd say that cam will likely pretty pretty radical. I had a 226/234, 554/575 and it was pretty noticeable. I woudn't want to be that the cam you mention will pass emmissions, but I've been wrong plenty of times before!
I've got this cam in my ARE STII setup. No problems with idle (though did need to drill the TB the lower the pintle counts) though a bit lumpy and the car pulls very strongly to its raised redline. Really nice if you like rowing the gears in and out of corners. I've got no interest in drag racing, so don't mind the slightly reduced low rpm torque. Nick knew that when he setup my H/C package, and picked this cam accordingly.
