changed 7 spark plugs so far and found
Old Jan 11, 2002 | 06:58 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Default changed 7 spark plugs so far and found
number 1 cylinder with more oil than the rest...is this normal to have oil blow by....only 7200 miles on the car?
How in the heck do you get to the last plug and boot on the drivers side...is there an easy way
Old Jan 11, 2002 | 07:09 PM
Ranger's Avatar
Ranger
Default Re: changed 7 spark plugs so far and found (iceburgh68)
Here is a terrific how-to by Kewlbrz. He talks about #7 and a tool that helps.
http://www.vetteguru.com/mods/ignition/
Ranger
Old Jan 11, 2002 | 07:23 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
How many missing 'pucks' on the stock plugs did you find? I'm doing mine this weekend.
I'm not a guru, but considering you are so close to the break-in time, I'd not worry about it unless it continues.
Are you consuming oil?
Good luck,
[Modified by SDVette, 3:28 PM 1/11/2002]
Old Jan 11, 2002 | 09:37 PM
ZO6LS6's Avatar
ZO6LS6
ice, I am of another persuasion..............
One plug with this scenario, is cause for further evaluation........
I would (since you have already changed them), watch that one, IF it is oil fouled again, have the coil checked for that cylinder first, and if it's ok......i would bet you have serious ring problems on that cylinder........
And if this is the case, make sure they replace ALL of them like the fix is supposed to be done..... :yesnod:
To changed 7 spark plugs so far and found
