uh oh...maybe damage after high speed run
Old Jan 11, 2002 | 10:40 PM
rwj383's Avatar
rwj383
Default uh oh...maybe damage after high speed run
well, it looks like i jinxed it after all. i hope not. i got the car up to very high speed yesterday while racing, as most of you know. well, i failed to mention until further into the thread that when i was leveling out, the motor was making a little bit of gurgling/pinging. i could barely hear it, but at those speeds, no wonder. well, i finally drove my car the first time since. there is a sharp kackle in the exhuast on deceleration. but, i do not have any mufflers on the car. therefore, there has always been a little bit of this when car was cold. well, i got the car warm and it didnt go away. very distinct kackle that wont go away now. DAM. the car feels ok, though. any thoughts?
Old Jan 11, 2002 | 11:02 PM
MelloYellow's Avatar
MelloYellow
Default Re: uh oh...maybe damage after high speed run (rwj383)
Check your plugs?
Old Jan 11, 2002 | 11:05 PM
MitchellDavidson's Avatar
MitchellDavidson
Default Re: uh oh...maybe damage after high speed run (MelloYellow)
Ya, I think that sucks. :nonod:
Old Jan 11, 2002 | 11:29 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Re: uh oh...maybe damage after high speed run (MitchellDavidson)
I agree you ran the n20 for a while your plugs are baked.
Let me know when the next time your going to run a top speed run. I would have to see it to belive that you did 217. :bs
Old Jan 12, 2002 | 12:20 AM
MrEracer's Avatar
MrEracer
Robert,
While you have the plugs out, give it a compression check... That's the best way to identify any piston/valve/ring damage after a heavy NOX run... Believe me, I have a lot experience in this area...
Shirl :D
Old Jan 12, 2002 | 12:23 AM
MelloYellow
Ya, dude.. Post a follow-up.
Good luck. You might be ok.
Old Jan 12, 2002 | 12:49 AM
Mr turbo rotary's Avatar
Mr turbo rotary
Like the above post check your plugs, do a compression test and also drain your oil and look for fine shavings (bearings,etc)..Good luck I hope your engine is ok.. :cheers:
Old Jan 12, 2002 | 01:09 AM
ZO6LS6's Avatar
ZO6LS6
Define "Kackle"....
You think you sucked a chicken into the intake at those speeds??. :eek:
Old Jan 12, 2002 | 02:32 AM
rwj383's Avatar
rwj383
Default Re: uh oh...maybe damage after high speed run (ZO6LS6)
Define "Kackle"....
it is a hard POP on decel, sometimes several one after the other. only sometimes, yet doesnt go away when car is warm. i just got back from an even further drive this evening. yup, i need to investigate. i hope it is only a chicken or small dog
Old Jan 12, 2002 | 09:04 AM
geekracer's Avatar
geekracer
Post a pic of the plugs if you can :smash:
Old Jan 12, 2002 | 09:11 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Pull plugs & check compression and do a leak down test. If you find there is a compression issue, first check pushrods then start possibly looking for a bent valve stem... Just a process of elimination... Sorry about your misfortune man!
Nick
Old Jan 12, 2002 | 09:17 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
I bet the Spyder does that have any problems after the run. :lol: :smash:
Old Jan 12, 2002 | 11:21 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: uh oh...maybe damage after high speed run (2000^C5)
Maybe its a damaged head gasket? The compression/leak down test should tell you the story.
Old Jan 12, 2002 | 11:29 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: uh oh...maybe damage after high speed run (Smoke-N-Shot)
If the engine is still strong, and this is the sound/only one it's making......I agree, comp test, and look at the valve train.............
Fuel is evidently combusting in the exhaust area........raw....plug/s, could be damaged.
Old Jan 12, 2002 | 01:44 PM
Austrian Vette's Avatar
Austrian Vette
:cry Uh, RWJ, didn´t want to heas that!!
1) What are your plugs gapped at??
Mine are gapped .34 on 200 shot runs!!!!!!!!
2) Also what octane did you use??
I don´t use less than 99 Octane.
I read .94 to 1.00 O2`s on my NOS runs...damn rich, but therefore
NO pinging!! Maybe you were too lean :(
Mabe you run out of fuel pressure?? That´s why I have an Autometer
fuel pressure gauge and have 60-61PSI during the runs.
On NOS you cannot be careful enough!!!
1st Check your plugs!!!!
2nd Check compression, your head gaskets may be gone
3rd Maybe the piston rings are not in perfect shape now :(
4th I hope you didn´t damage your drivetrain.
5th Do you have cats???? You may have burnt them!!!
I´m no mechanic, but however, post all news and I´ll try to help you out as good as I can!!!
Hi Speed junkies hold together, my friend........we will find out what doesn´t work well !!!!!
BTW, I´ll see what my internal engine looks like after the big NOS runs
next month, wehn I do the heads/cam swap.
Good luck and let me know!!!
Michael
[Modified by Austrian Vette, 6:48 PM 1/12/2002]
To uh oh...maybe damage after high speed run
