part numbers
Old Oct 29, 2008 | 06:34 PM
brookman's Avatar
brookman
Default part numbers
Does someone know the part numbers for the following exhaust parts?
The studs on the exhaust manifolds (3 per side facing down)
mine are bent from bottoming out
the o ring gasket for the above connection with the metal sleeve
and the two gaskets at the back that are right before the pipes go over the rear axles.
Old Oct 29, 2008 | 06:47 PM
lucky131969's Avatar
lucky131969
Yep, just did it this winter:
Stud : 12561310
Donut gasket to exhaust manifold: 12555555
catback flange gasket: 10276792
Old Oct 29, 2008 | 08:56 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Feel free to contact me if i can be of any assistance.
Old Oct 29, 2008 | 09:44 PM
brookman's Avatar
brookman
Thanks so much for the info. I looked up the part numbers you sent and it says the part 12555555 is
Exhaust system - Exhaust components - Intermed pipe - Seal Seal - 6.0 liter 2005 - 2008
same for model year 2000?
Old Oct 29, 2008 | 11:46 PM
lucky131969
Must be, that's what I put on my 99.
To part numbers
