Clutch master/slave failure???
Old Oct 30, 2008 | 09:45 PM
bartsky's Avatar
bartsky
Default Clutch master/slave failure???
I have an 02 Z06 that I just can't hardly even get in in gear. The resevoir is very dirt, and gunk in it. When you engage the clutch then release you can hear a banging noise. When I sit there and pump clutch like crazy, you can get in gears. Does this sound like clutch master and or slave cylinder failure?
Old Oct 30, 2008 | 10:59 PM
LoneStarFRC's Avatar
LoneStarFRC
From your description, it sounds more like a M/C problem than a slave. Usually when the slave pukes, it starts leaking fluid. The master cylinder may or may not leak. It may be bypassing internally and won't generate enough hydraulic pressure to operate the slave. It could also have air in the system and cause problems too.
Is your system leaking? Are you having to add fluid? Have you tried bleeding it in case there's air in the system?
Old Oct 30, 2008 | 11:07 PM
11SECSS's Avatar
11SECSS
This is true... we need to know if shes leaking fluid
Old Oct 30, 2008 | 11:49 PM
bartsky's Avatar
bartsky
Well I just bought it from out of state. It arrived on truck and would not go in gear. That was my plan to have system bled initially, then probably put master in.
To Clutch master/slave failure???
