Hi flow cats
Old Oct 31, 2008 | 10:00 PM
RtStuf's Avatar
RtStuf
Default Hi flow cats
How much, if any, gain w MagnaFlow Hi Flow cats?
Old Nov 1, 2008 | 01:03 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I would say very little--3-5 HP--AND you have to be sure that the ones you chosse will indeed pass emissions--here in Calif--most Hi-flow cats won't and the only ones that will are the Random Tech's and they are very pricey-I made the mistake of intalling some of the bullet style SS metal substrate hi-flows--They claimed to be Cailf legal--Were only $70 each---BUT had to remove them as they weren't even close as the Nox was way over-- Put the stockers back on-----IMO-not worth the trouble--A good X-pipe is better--
Old Nov 1, 2008 | 07:05 AM
aleadfoot's Avatar
aleadfoot
Old Nov 2, 2008 | 12:21 AM
RtStuf's Avatar
RtStuf
More opinions?
Old Nov 2, 2008 | 01:18 AM
motogib1's Avatar
motogib1
You will not feel the hp from hi-flow cats alone so whats the point. Hi-flows are normally installed as part of a header installation and you will feel the hp from that!!
Old Nov 2, 2008 | 06:16 PM
LT1GMC's Avatar
LT1GMC
Hi flow cats really are only worth it if you have long tube headers and need them cause the factory ones won't fit. There is not enough gain otherwise. I can smell that my hi-flows don't work like factory, when cold anyway.
To Hi flow cats
