00 vert door function problem
Old Nov 1, 2008 | 04:13 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default 00 vert door function problem
On my dads vert the passenger side door functions work when they want to. One time the switches will work next time they wont. They wont work using the driver side as well or the window wont go down when you push to open the rear deck. I am guessing it is a ground problem. Where should I start to look
Old Nov 1, 2008 | 07:27 PM
rws.1's Avatar
rws.1
I would first look to the door control module.
take off the inside door panel and check the connections to the module and the wiring to make sure it is not cracked or broken.
Old Nov 1, 2008 | 08:44 PM
Nowhere Man
ok do you have a link on how to take the door panel off.
To 00 vert door function problem
