Ok so I know how to program my remotes. And I have them programed but anytime I use them the mirrors and seat goes to a different preset. I have the factory service manual and owners manual but can not find anywhere on how to change the presets. I have a 98 convertable. Hopefully someone out there can help.
thanks for the help. I don't have the memory buttons but my mirrors and seat moves to the same positions when I use the fob. My car has a salvage title. So I am thinking the switch might have gotten replaced with one with out memory buttons I'm gonna pull the switch and see if it has a extra conector back there.
Memory Buttons on drivers control panel on door arm
If you have MEMORY and the WRONG control panel you might find one in the parts section here or on fleebay. I had a bad LOCK button on my panel and someone here suggested looking on fleebay. The $120 or so GM part cost me about $35 and maybe $10 shipping from a JAZZIEJUNK in Florida. Looked and worked like new and the price was right.
My 98 can have 3 remotes which correspond with MEMORY 1, 2, and 3.
You set them by setting your mirrors, radio, HVAC temp, mode and speed, and seat position then HOLDING the appropriate memory button on top of the panel down until the yellow LED flashes. Memory 3 is set by holding both buttons 1 and 2 at the same time and waiting for the LEDs to flash. On mine the order you program the remotes makes it Mem 1, 2 or 3. The first one programmed is Mem 1, Second is Mem 2 and the third is Mem 3. On 2000 and later think there are only 2 remotes 1 and 2 but I have no experience here.
Hope this helps you out.BIGHANK
Thanks again
Kevin
You can check to see if the car came with the Memory option by checking the sticker in the glove box (assuming it's the original) for RPO AAB "Memory, Driver Convenience Package."
