Ls1 max rpm
The C6Z is rated at 505 BHP that will equate to something like 425 RWHP, and I suspect that with a competant driver 11.3 - 11.5 is more likely on street tires. On drag radials i think 11.0 is within range.
A C6Z on DR's has run 10.9x, a C6Z on stock tires will run low mid 11's in good weather. One of the guys I race with has a C6Z and he is usually a 1/10th or 2 faster than me when he's on street tires and I will run mid-high 11's on DR's
The OP needs to clarify whether or not its the shift light that goes off at 6k or the if he hits the rev limiter.
The light may be set low by the orginal owner to comply with softer driving habits. Take her out and get on her and see where the limiter kicks in or bring it to a tuner and have it run on the dyno again to find out for sure.
Another thing I've heard is that with a bigger cam the valve springs have a short life. If you got miles on the engine, you won't be able to safely spin it as high anymore. The higher performance you get out of a engine, the shorter the life of some of the parts. And, if you race then everything is a consumable
These are just some of the issues I've read about, don't have a whole lot of experience so I could be wrong.
So, its hard for anyone to say exactly how high you can go. If the engine was fresh then maybe you could be safe up to 6,500, maybe, but it would be better to have it evaluated by someone who knows LSx engines before spinning it up high.
