Steering Position Sensor Replacement
Old Nov 2, 2008 | 05:40 PM
EtidW's Avatar
EtidW
Default Steering Position Sensor Replacement
I keep getting a 1287 code which is the steering position sensor so I figure that it is toast. Has anyone out there replaced this and if so do you have any pics or procedure. I did a search but could see what i was looking for.
Old Nov 2, 2008 | 05:50 PM
DIXZ's Avatar
DIXZ
Do a search in C5 Tech for Steering Position Sensor. There is a very good write up by Mathia!
Thanks for the write up Mathia
It helps to have an extra pair of hands when you feed the column back through the firewall. Took the two of us about an hour!
Old Nov 2, 2008 | 06:20 PM
stormrider's Avatar
stormrider
I have instructions with pics in Word format. PM me you email address and I will send them to you. Word of warning, it isn't that hard of a job unless you have power telescopic steering wheel then it is a PIA. It took Cobra4b and me almost 6 hours to switch mine out and still haven't gotten the telescoping mechanism hooked back up.
Old Nov 2, 2008 | 07:04 PM
DIXZ's Avatar
DIXZ
Stormrider, I had no idea that the tele column is that much More involved! Best of luck getting this buttoned up!
Old Nov 2, 2008 | 08:14 PM
stormrider's Avatar
stormrider
Yea, the motor sits on the steering column down by the fire wall and it is hard as he!! to get it out and back in place due to the lack of room. If I was to do it again I think I would have paid someone else to do the work and you wont hear me say that very often.
Old Nov 2, 2008 | 09:00 PM
rws.1's Avatar
rws.1
I have the telescoping wheel and decided to have it done by the stealership because of the telescopic function....
Old Nov 2, 2008 | 10:21 PM
byronhunter's Avatar
byronhunter
Posted in wrong thread, sorry!
Old Nov 3, 2008 | 04:40 AM
Bluefire's Avatar
Bluefire
I had my local dealership replace mine two months ago. $70 for the sensor, $220 labor. Quite a deal IMHO.
Old Nov 3, 2008 | 10:49 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, same here...I had the dealer do it for me therefore if they set off the air-bag, its out of their pocket and not mine
Old Nov 3, 2008 | 01:26 PM
Bluefire's Avatar
Bluefire
BINGO! I didn't want to chance getting the "800 MPH powder puff" to the face.
To Steering Position Sensor Replacement
