well i removed my ebcm and sent it off for repair,but i chose this gut on ebay who charges $100.00 to save 50..00 ,i got it back promptly but the trouble is worse now,i get ser traction controll and abs codes and lights ,anybody have this ,i checked fuses and tryed disc bat,,,dont see and abs fuses ,to check ,i guess this guy just didnt fix it
OK...now do this...send it to Brandon @ abs fixer
For EBCM repair/replace
Call Brandon
877-648-7530 at ABS FIXER
or: www.absfixer.com
$150. plus UPS....warranted as long as you own it
Many things can cause this problem. It may not be the EBCM.
What codes are you getting?
1225/1226 codes are typical for problems of errroneous errors from wheel sensor speed circuits. You must get the codes to narrow down the fault.
