Need Input on X-Pipe Installation
I'm going to try to install a B&B X-pipe on my 02 6sp coupe. It currently has the stock exhaust manifold, the stock H pipe, and a B&B bullet exhaust.1. Car on 4 jack stands, hold X-pipe even with where it bolts to the bullets and mark H-pipe for the cut. I'll mark it just before where the X-pipe slip joint narrows so as to maximize the amount of overlap at the slip joint.
2. remove bolts connecting bullet to the H-pipe. Using a chain tubing cutter, cut the H-pipe at my marks. Apply bandaid to head where H-pipe dropped on me.
3. Put clamps on X-pipe and slip it on. Snug clamps a little. Bolt the other end to the bullets.
4. Line up the tips, then tighten the clamps, then the bolts.
5. Have a frosty cold adult beverage...
Am I over-looking anything? Thanks for your input!!
Lining up the cat backs after is usually a process of tightening front to back. I support the catback tips to keep them aligned using the method shown below.
