If It is the standard H pipe replacement size X pipe (Not a custom size like a 3") Yes it should fit. The rear 2 bolt flanges at the rear (for the over axle) pipe are standard size.
supposedly interchangeable. call borla if you really need the holy grail.had xpipe with my corsa indy installed and never thought i was particularly quite. removed and installed kooks headers. is significantly louder at wot sounds like a banshee scream at 5000 plus rpm's
OK yes i am digging up an old thread. Like others have said have you searched... So I searched and this is what I have found.
I have Corsa axle back exhaust hooked up to factory H. I want to go X pipe. But not sure if:
1. Will Borla's X pipe will work with Corsa Xtreme? From what I can tell it should but looking for confirmation.
2. If it will work any positives or negatives with that setup?
Main reason I am asking is to see if the Corsa is worth the $100+ more in cost for the X pipe compared to Borla?
Thanks all for your help.
Just to update for anyone elses benefit. I did buy the Borla X pipe and it fit just fine with the Corsa axle back exhaust. Sounds awesome 😄 and took the popping noise away. It gurgles some where before it was more popping. Which is fine. At cruise speed not too noisy at all. And when you excelerate it has a good sound. Very happy with the results.
