Cutting shock jounce bumpers
Old Jan 13, 2002 | 04:15 PM
6Speeder's Avatar
6Speeder
Default Cutting shock jounce bumpers
Earlier, there was a suggestion to shorten the shock jounce bumpers to give a little more suspension travel after lowering the C5. Has anyone done this, did it work? :confused:
Old Jan 13, 2002 | 05:44 PM
MelloYellow's Avatar
MelloYellow
Default Re: Cutting shock jounce bumpers (6Speeder)
Others have. I'll be doing mine in 2 weeks. Z51 Suspension. Will be reversing the rear mounting brackets & cutting the front bushings also. Longer rear bolts too.
Old Jan 13, 2002 | 06:29 PM
6Speeder's Avatar
6Speeder
Default Re: Cutting shock jounce bumpers (MelloYellow)
Mello: Cool, let us know how it works. Are you doing anything to the front shock mounts? :cheers:
Old Jan 13, 2002 | 06:53 PM
MelloYellow
No. I don't think you can change those? Guess I'll have .5" less travel up front... I'm thinking you see more shock travel at the rear of the car, but I could be wrong..? Reverse, but with the mount/jounce mods I should have more travel after I lower and address those issues than I do have in my current setup with less lowering. So I should be ok.
Old Jan 13, 2002 | 07:41 PM
NastyC5's Avatar
NastyC5
I cut my Bilstein stops and It did make a difference :yesnod:
I also experimented with my Z51 shocks. My car is slammed, so I felt the Z51 shocks were a little to sloppy.You can cut the stops with a razor blade.
Old Jan 13, 2002 | 08:48 PM
MelloYellow
Default Re: Cutting shock jounce bumpers (NastyC5)
Nasty:
How much were you lowered with the Z51's and cut Z51 stops? Did you cut .5"? Did you cut the Z51 stops with the shocks still installed or didya remove them 1st?
Thx!
Old Jan 14, 2002 | 04:41 AM
NastyC5's Avatar
NastyC5
MelloYellow I cut the smaller part of the stops. If you look at the stops they are 2 teared. I cut the smaller part off when I had the shocks off the car.
My car has no :eek: front bolts and longer (RKSport) rear bolts.
Old Jan 14, 2002 | 09:05 AM
Scott97's Avatar
Scott97
I used a steak knife to cut mine. :D
Works pretty well.
Old Jan 14, 2002 | 12:42 PM
6Speeder's Avatar
6Speeder
Default Re: Cutting shock jounce bumpers (Scott97)
Scott97: Sounds tasty! :lol: Did you have to remove the shocks, or could you get to the bumpers while on the car? :cheers:
[Modified by 6Speeder, 10:43 AM 1/14/2002]
Old Jan 14, 2002 | 12:49 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Call me dumb, can anyone show a picture of these jounce bumpers, or explain where to find them. Also, do you just undo the shock at the top and turn that bracket upside down and reinstall the shock? Thanks. :cheers:
Old Jan 14, 2002 | 01:30 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Default Re: Cutting shock jounce bumpers (racer44)
Here is a pic before I cut them, I'm using the b type bumper cut in half.
The gaps shown are where the shocks were on the car with a distance of
26 1/4" to the fender well. Now I'm at 26" with the bumpers cut 1/2".
Old Jan 14, 2002 | 03:07 PM
daveydc5's Avatar
daveydc5
Default Re: Cutting shock jounce bumpers (Flyin'Brian)
Interesting pic. Most people say that the Bilsteins are the same length as the Z51 shock. The pic seems to show that the Bilstein is shorter. Anyway, I just received a set of the Koni adjustables. These seem to have a very soft foam rubber bump stop.
My biggest concern with lowering and cutting or using a soft bump stop is internal shock bottoming. At $220/ea, I really don't want to kill my shox by lowering too much. I'm really more interesting in optimizing handling than just slamming the car for looks. However, if I can have both, why not?!
To Cutting shock jounce bumpers
