Six wires from Throttle position sensor
Old Nov 9, 2008 | 07:40 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Default Six wires from Throttle position sensor
Can someone share what pins on the PCM or where the 6 different pins go from the TPS back? Also what voltages or ground is supposed to be on them? Thanks!
Old Nov 9, 2008 | 08:08 PM
Patches's Avatar
Patches
TPS connector end view
The schematic
Old Nov 9, 2008 | 08:18 PM
Z06PSI's Avatar
Z06PSI
Wow... Thanks for the quick response. Hopefully I can get this hunk of junk running.
Old Nov 10, 2008 | 07:53 AM
Z06PSI's Avatar
Z06PSI
So the pink wire should be my return voltage and it should be around .65V key on.
To Six wires from Throttle position sensor
