I was thinking about the 2MPH fuel cutoff issue that a friend of mine is battling. I know that numerous people have had it turned off with a tuner, however I may have figured something out but need a schematic of the relay wiring that the PCM shuts off
Does anyone have a schematic of that relay wiring they could post?
I'd like to know more about the 2 mph fuel cutoff, could you explain how/why it works?
I could be mistaken, but I highly doubt you'll find any external wiring or relays related to this. At least there should be no need for that.
The BCM and PCM communicate via the serial data bus, and anytime the PCM gets the nod from BCM to shut down, the PCM does so by not firing the injectors. What the GM recall did was tweak the BCM to introduce this particular shut-down command in column lock failure situations.
Tuning software can break/alter that BCM command, but I don't think you'll find a wire to snip or a fuse to pull that will stop it.
That's the simplified version as I understand it.
Thats what Im looking at...Tuning software only sends a command to tell existing hardware how to act, so it can be done.
What GM did was introduce a software scenario to over ride the original factory operation. Numerous people including my friend have this issue after having the recall done and after installing a CLB. Prior to GM implementing the recall and the reflash I don't see a history of the 2MPH cutoff being a problem? I believe I have figured out a hardware solution to this problem, However I would like to verify my proposed solution against the wiring schematics prior to implementing them in my friends car.
I do know it can be "fixed by a tune" however I would like to find a solution that is not as cost prohibitive and also helps those that are not close to a tuner.
My car had 2 of the recalls done before I bought it. The 2nd one,, RC04006 included the words "Perform reprogram and functional test" theis was in case their crappy K harness F**ked up it would kill the fuel over 2mph. I can verify IT DOES!!! Ask me how I know!!!:cheers :
Yes, but my point was...with software changes you are not dealing with wiring schematics...because there are none. No hard wiring changes took place.
If you think you can break the communication between the BCM and PCM completely, your car will not start or run, period. (without software changes - PCM tuning).
I think you're looking at this wrong.. it's not that a wire suddenly gets voltage when the 2mph cutoff is in place.. the PCM knows that it's limited to 2mph and then kills the fuel when it detects it at 2mph. You CAN NOT cut a wire and have the car continue to run and avoid the 2mph cutoff. It's dead simple to get rid of in HPtuners, your buddy needs to find someone with a copy and get it taken care of...
Anyone with the commercial version of HP Tuners can adjust the 2mph cutoff to 255mph in 5 minutes if that. If they charge you more than $20 kick them in the nuts.
P.S. Should have stayed the hell away from the dealer.
