How can I find the code for my lug nut Locks?
Old Nov 10, 2008 | 10:14 PM
Blu_NC_Z06's Avatar
Blu_NC_Z06
4th Gear
Default How can I find the code for my lug nut Locks?
Hi to all. I can not locate the key to the wheel locks on my Z. Is it possible to get the code for the key from my VIN? Thanks for any help.
Did search and no luck
Old Nov 10, 2008 | 10:15 PM
lucky131969's Avatar
lucky131969
give the dealer a call......
Old Nov 10, 2008 | 10:36 PM
01Z06 Black's Avatar
01Z06 Black
St. Jude Donor '08
There should be a card with the code in you owners manual.
I had to call the manufacturer of the locks, and they gave me the name of a local dealer that had a master set to remove the wheel locks.
Old Nov 10, 2008 | 11:39 PM
lionelhutz's Avatar
lionelhutz
Lots of shops will have the tool kit to remove those locks. I know my friend does at his body shop. I've used it before. I know this doesn't help with your key but they aren't hard to remove. I've even done it before with a socket and big hammer.
Peter
Old Nov 11, 2008 | 08:13 AM
minitech's Avatar
minitech
Another place to get them off or maybe buy a key is a salvage yard. They need to get wheels off often times not having the key. And collect keys they run across.
Old Nov 12, 2008 | 07:11 PM
bykerboy's Avatar
bykerboy
13/16" deep socket, 5 lb. sledge and a 1/2" breaker bar will do the trick. I removed mine and just put stock lug nuts back on. They are not worth the hassle in my opinion.
Old Nov 12, 2008 | 07:35 PM
SUNNYD 95's Avatar
SUNNYD 95
I don't have the locks on my wheels, if they want the wheels they'll get them, with or without the locks.
If they want them bad enough they'll take the complete car not only the wheels.
Old Nov 12, 2008 | 08:42 PM
65GGvert's Avatar
65GGvert
Just for grins, I'll ask. Did you look under the carpet in the rear in the indentation in the trunk floor by the rear storage compartment? That's where they were stored. Check just in case.
Old Nov 12, 2008 | 10:12 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I stopped by the local GM dealer and asked the parts guys. They almost always keep a set for use in the shop.
He handed me the box and I walked out to the car and ran through the set till I found the one I needed.
Old Nov 12, 2008 | 11:33 PM
Plasticman's Avatar
Plasticman
Please do not use a hammer (to hammer on a socket over the locking lugnut)! Best way I know to destroy a wheel bearing. Hammering directly on the wheel indents (brinnel) the bearing race.
http://www.emersonbearing.com/fail_truebrinell.htm
Fine for removal in a junk yard, but don't do it on your Vette.
Plasticman
Old Nov 13, 2008 | 12:12 AM
lucky131969
Y'all come back now.....hear!
Old Nov 13, 2008 | 01:28 AM
bykerboy's Avatar
bykerboy
Old Nov 13, 2008 | 07:20 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Bingo!
Old Nov 16, 2008 | 10:59 PM
Blu_NC_Z06's Avatar
Blu_NC_Z06
4th Gear
Thanks for all the replies. The dealership wanted me to make an appointment to have them removed, but I'm the kind of person who likes to have things fixed asap. So I went to Pep boys and picked up a lug nut remover set for 20$ and some replacement lugs until my order for the threaded set arrive on Tuesday. It took all of 10 minutes max to remove them and put the replacements on. The trunk was the first place I looked per the owners manual. Thanks for the reply though, I know alot of people ignore their owners manual, so you have to ask. Thanks again
To How can I find the code for my lug nut Locks?
