Air compressor filter mod captured it
Old Nov 12, 2008 | 12:09 AM
skidmarc's Avatar
skidmarc
Default Air compressor filter mod captured it
White milky liquid with slight tinge of brown....is this normal??? Normally catches blk thin oil?
Thanks for any input!
Old Nov 12, 2008 | 12:32 AM
striper's Avatar
striper
Sounds like somewhere you're getting coolant and oil mixing. Not a good sign.
Old Nov 12, 2008 | 04:05 AM
mathia's Avatar
mathia
I've gotten that a couple of times. I think it's just from condensation. Almost always it captures all oil. When on the track (road course) it captures quite a bit of oil, probably cause I'm hold high RPMs with partial throttle.
Old Nov 12, 2008 | 10:36 AM
hotwheels57's Avatar
hotwheels57
Especially now that the weather has turned colder and if you don't drive it often enough and long enough to burn off the condensation that is part of the combustion process. It's the same thing as the water you probably see dripping from your exhaust during colder days...
Old Nov 12, 2008 | 12:34 PM
DevilMan02's Avatar
DevilMan02
I'm 25 living in the mind of a 13 year old boy...(grinning ear to ear)
To Air compressor filter mod captured it
