Oil Pressure questions!!!
Old Nov 13, 2008 | 04:04 PM
04C5's Avatar
04C5
Default Oil Pressure questions!!!
My oil pressure gauge has been acting up. The needle will be pegged all the way to the right indicating the highest oil pressure possible, then after driving it for a bit it will drop to ZERO! Then after another while, guess what... it will sweep all the way over to the right again!! I'm guessing the oil pressure sensor is jacked but dont really know...
Any ideas out there in Corvette land??? Thanks for any help!!!!
Old Nov 13, 2008 | 04:20 PM
lucky131969's Avatar
lucky131969
use the search function for "oil pressure".....also, read the sticky at the top.
Old Nov 13, 2008 | 05:11 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
These crazy indication issues are almost always a bad oil pressure sending unit. Next time your OP guage pegs at 80, cycle your DIC to it's oil pressure reading, and see if it says 130 PSI there. Also, make a note of whether this happens even when the engine isn't running (but with key in the "on" position). Generally, when these fail the needle stays pegged, but it can fluctuate wildly as well. Plus, considering these things fail often, it's a safe bet that you've probably got a wonky sensor. It happens.
They run something like $40 from the Forum vendors and you can do it yourself if you have an afternoon, some tools, and a beer. The sticky up top has links to the how-to's on this.
Good luck!
Old Nov 13, 2008 | 05:16 PM
J.R.'s Avatar
J.R.
Ready sticky at top.
Remote sending unit is the answer. If you don't believe it spend 2 plus hours replacing sending unit and find that the new unit you replaced is bad and you have to start all over.
Old Nov 13, 2008 | 05:58 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
It is a small dwarf or troll behind the gauge. Common problem with the C5. Chevy part #24536, special tool for removing said dwarfs.
Old Nov 14, 2008 | 06:31 AM
rws.1's Avatar
rws.1
here is a link to the best DIY for this problem...
http://forums.corvetteforum.com/c5-t...y-vectorz.html
To Oil Pressure questions!!!
