Body squeeks making me crazy!
The sound seems to be coming from the bottom center of the car, most of the time, but at times it sounds like it's coming from in front of the driver.
Anybody else experience this problem? Is this typical of c-5's ? Could it be the torque tube wiggling around a bit as the frame flexes? Is there a spot you can shoot some WD-40 or silicone on to get rid of the CHIRPS? I just replaced the shocks and that did nothing to fix this issue, despite my guess that this could be suspension related.
Any help would be appreciated.
Thanks,
Bluemill
COME ON GM, FORD, & CHRYSLER, YOU CAN DO IT!
Easy job once you get the car high enough to get access to the bushings.
Good luck.
If I put the car on on 4 jackstands could I get the same effect?
What was your final fix method?
Thanks,
Bluemill
Bill
The corvette's stiff suspension promotes a squeaky environment. But remember there is a solution for any level of squeak...really loud exhaust!
