c5 pcm help
Old Nov 14, 2008 | 03:55 PM
camaro69's Avatar
camaro69
Default c5 pcm help
bought a c5 with the pcm missing i know it goes on the passanger right but not sure how it gets mounted and to what. i bought a new bracket and pcm any help please
Old Nov 15, 2008 | 12:21 AM
T.J.'s Avatar
T.J.
Just do a search for PCM removal or something like that and you should find a few posts to help with good pics.
Old Nov 15, 2008 | 01:01 AM
4DRUSH's Avatar
4DRUSH
Remove the r front wheel, towards the lower rear of the inner fender well there's a separate peice that can be removed. remove the lower fender bolts also and flex the lower fender out. The pcm gets mounted there inside the fender.
If you need more help call ECS
http://www.eastcoastsupercharging.com/index.html
Old Nov 15, 2008 | 01:23 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
This help?
Old Nov 15, 2008 | 10:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Know too that it will have to be programmed before the car will start. Security, RPO codes and so on have to go into it.
Old Nov 16, 2008 | 04:47 PM
camaro69's Avatar
camaro69
thanks for the help didn't realize it bolted that low. thought it bolted to the fender well. but thanks again. rick
Old Nov 16, 2008 | 08:08 PM
'VETTE PHASE
That is actually the frame rail.
Old Nov 16, 2008 | 09:31 PM
Choreo's Avatar
Choreo
What keep this dry when going through an intersection with poor drainage when it rains? ... or does it just get drenched?
To c5 pcm help
