proper run flat tire pressure..
Old Nov 17, 2008 | 06:21 AM
Storm2313's Avatar
Storm2313
Default proper run flat tire pressure..
I have the stock runflats and was wondering what you guys run for optimal everyday use?? I know I can look at the inside of the door, but sometimes I like other peoples opinions..
Old Nov 17, 2008 | 08:01 AM
65GGvert's Avatar
65GGvert
Other people's opinions can be wrong, the door sticker is right. 30 psi cold.
Old Nov 17, 2008 | 08:40 AM
99 vett babycar's Avatar
99 vett babycar
Old Nov 17, 2008 | 08:49 AM
lucky131969's Avatar
lucky131969
After all, service manuals, owners manuals, and silly little stickers on the door, are only to be used as guidelines.....if the engineers really knew what they were doing, they would not have put the oil pressure sensor under the intake manifold.....right?
I feel better stepping outside of the manufacturers guidelines when I see other guys on the forum feel the same way.
Old Nov 17, 2008 | 08:51 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
mine are usally around 27 psi, and they ride nice
To proper run flat tire pressure..
