The passenger window on my 02 vert does not go down when the passenger window switch is pressed on the drivers door or the passenger door. I just hear a soft clicking sound; I tried it with the engine running and with the engine off same result please advise.
If you hear the door relay click and the window does not move, you probably will have to replace the whole window regulator assembly to fix it. You may be able to unstick the motor and get it to work for awhile, but once they mess up, you can never tell when it will quit working again.
I had a similar problem on my 2000 HT. I hit the door panel pretty hard with my hand in front of the speaker and the window started working. This "fix" has held up for over a year
i just tried this yesterday.
unbelievable
it actually worked. even if just for the time-being(?) im thrilled to have it work.
i had to hold the 'down' button while giving a good thud to the area behind the speaker (a really good thump)
