Ho no ! Another MAF Screen Post
Old Nov 18, 2008 | 04:47 AM
Brice's Avatar
Brice
Default Ho no ! Another MAF Screen Post
But this one is different.
I've got hptuners and a wideband so I can tune my MAF with or without screen.
but...
I've installed a Callaway Honker which relocate to MAF next to the Throttle Body. They're really a short path between them.
Is it a good idea then to remove the screen ?
Callaway is 50 states legal with C5 but non with 02-05 C5 Z06 (ie maf without screen)
Any experience ? thoughts ?
I've just buy an LS6 intake si I have to retune my VE tables... to descreen or not descreen, that is the question
Old Nov 18, 2008 | 09:27 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If it came with a screen, the screen should stay. The screen makes the driveability better by preventing erratic events due to non-linear airflow across the sensor. If you want no screen, buy the Z06 MAF and re-write your MAF table. JMHO
Old Nov 18, 2008 | 02:20 PM
dieseldave56's Avatar
dieseldave56
Default '01 LS6 w/ screen ...........
The '01 LS6 with MAF screen and the '02-'04 w/out. GMPT engineers left the screen on the MAF to 'straighten' out air flow. Over looked on the '01 ZO6 M/Y it was removed in later model years because it was not needed as the air flow has a relatively straight shot from the air fliter box to the MAF with the new ( LS6 '01 M/Y) air box and larger lid opening in LS6 '02 M/Y. According to Asst Chief engineer John Juriga; the addition of the '02-'04 Z06 air box and the removal of the MAF strightener screen brought approx 5 hp increase.
Any use of the MAF with an air intake duct that curves just before the MAF, needs the straightener ( or screen) for the MAF to sense acturatley. Which is why , in GM's conventional wisdom , they left the screen on. We have been de-screening the MAF in conjuction with rerouting the ducting with no problems .
I have added the '02 Z06 air box and removed the screen ( plus swapped out the '01 Z06 exhaust for the '02 Z06 exhaust.). Had the PCM recalibrated .No problems with low speed drivability as some have reported with just the removal of the OEM MAF straightener screen on LS1 applications.
Old Nov 18, 2008 | 02:30 PM
lucky131969's Avatar
lucky131969
but...
I think you should do it. Cut that sucker out of there and tune away
Old Nov 18, 2008 | 02:39 PM
Corvette Don's Avatar
Corvette Don
Just removed mine yesterday and noticed no difference what so ever, high or low rpm.
Old Nov 18, 2008 | 10:19 PM
lucky131969
What did you notice? More torque? Better throttle response?
Old Nov 19, 2008 | 07:07 AM
Corvette Don
There is more Throttle response for sure but I cant say it made an improvement cause I did add more timing up top also.
To Ho no ! Another MAF Screen Post
