Flashing Check Engine Light... but no codes??
Old Nov 18, 2008 | 01:06 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
Default Flashing Check Engine Light... but no codes??
New C5 owner here I have a 2001 Convertible that has had a cam, heads, and headers put on by the previous owner. Car runs GREAT, however it does give me the flashing Check Engine light at times. It does not throw any engine codes. It seems to come on usually when at a steady speed in either 5th or 6th gear, especially when going up a slight incline. There is NO power loss, doesn't seem to run rough, or any other indication that there is a problem. I took it to a tuner last weekend to have the tune checked and he found nothing wrong. We had the computer hooked up while driving and the Check Engine light did start flashing. He ran tests and NOTHING showed up. He checked for Misfires and the computer showed nothing. Everything appeared good to him.
What other conditions could exist that could be causing the computer to do this? What other things could be checked to narrow down the problem? I am not mechanically inclined so any help would be appreciated
Thanks!!
Old Nov 18, 2008 | 05:33 PM
dougbfresh's Avatar
dougbfresh
Flashing MIL is "USUALLY" a random misfire, check to see if there are and P0300's left in the computer.
Old Nov 18, 2008 | 05:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Have your tuner check if P0300 is set to "Not report" in your current tune. It will do exactly what you are describing.
My cammed car used to set off the false misfire (and flashing CE light) at idle due to the loping. I initially turned P0300 off and set to no MIL, but the flashing engine light continued, just w/o the code displaying. I bet whoever tuned your car did this.
So, if you re-enable the code, it will still flash the light, only difference you'll see is that P0300 is reported along with it. Doesn't really fix the issue of why the misfire is being detected when the car is running smoothly. If it were strictly an idle thing due to the cam lope, I'd tell ya how to fix it, but that doesn't seem to be your issue.
Old Nov 18, 2008 | 05:56 PM
Bill Dearborn's Avatar
Bill Dearborn
A flashing CEL indicates a misfire condition that could potentially damage the catalytic converter.
Bill
Old Nov 18, 2008 | 07:17 PM
PatternDayTrader's Avatar
PatternDayTrader
You should perform the "crankshaft variation relearn" procedure, if you are having misfire codes set but not really suffering from a missfire.
Old Nov 19, 2008 | 12:13 AM
87 Ragtop's Avatar
87 Ragtop
No P0300's showing. Ironically, it wasn't even showing any misfires when the computer was directly hooked up to it.
This may be the case. I'll have to send him an e-mail and see if the history shows this. It has popped up if I'm stuck at idle for a few minutes. It does seem to happen when I'm at a steady speed / RPM after a few minutes. Could probably be considered the same scenerio. It's been around 1700 RPM or less when it does kick up. Living in Ohio doesn't give me much chance to keep the speed above 70 ish in most cases.
Old Nov 19, 2008 | 12:14 AM
87 Ragtop's Avatar
87 Ragtop
Bill
I'm not sure that would be an issue....
Old Nov 19, 2008 | 12:15 AM
87 Ragtop's Avatar
87 Ragtop
I did a quick search on this. It looks like this would have to be done by a tuner? This might be my answer right here. I'll also ask him about this.
Thanks everyone for the suggestions
To Flashing Check Engine Light... but no codes??
