What made my car do this??
Old Nov 18, 2008 | 04:01 PM
intoc6s's Avatar
intoc6s
Default What made my car do this??
I was driving along and i wanted to see how my car sounded with the new "quieter" B&B route 66 cat back.(i had the straight pipe cat back) Anyway...I stomped it through 2nd....3rd....into fourth..about 100ish. Pretty much spinning and smoking the tires the whole way..All of a sudden, Smoke everywhere!!! coming from my exhaust!! Even when i pulled up to the stop sign. It kept smoking! So, i limped it home and jacked it up and.....NOTHING!! I remember Jason(black99) said that they might smoke some cause he got oil in them somehow..... Could that oil have stayed in there for a few days and not burned out till i Floored it?? I drove it for days normally. (I didn t get the tach above 3500 probably) Was it just the oil burning out??? I hope so...... - Jason
Old Nov 18, 2008 | 04:03 PM
BanditSRT's Avatar
BanditSRT
New exhausts are usually coated in something to make them look good. After they heat up, the coating burns off and smokes.
Old Nov 18, 2008 | 04:04 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Old Nov 18, 2008 | 04:28 PM
timemender's Avatar
timemender
intoc6s - So what did you think of the new sound?
Old Nov 18, 2008 | 04:42 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
The only time mine smoked like that was when I was running it hard 100+ and had worn rings that caused pressure to push the oil out of the dipstick onto the headers - smoke galore - thought Ihad blown the engine It would only do that when I pushed it HARD - normal driving would not exhibit the issue. Had to get new rings - because only three out of 8 pistons had two compression rings - 5 only had one ring - the top one - so when it started showing wear around 38K - the problems started with pushing the oil out...
Old Nov 18, 2008 | 06:06 PM
intoc6s's Avatar
intoc6s
Even with a heavily modded 7.0 liter(427) it has a "factory" sound! I ve got 1 7/8 Kooks headers and a "no cat" X-pipe, too! If you want to have a car that s stealthy, this is the way it should sound! I wouldn t believe it wasn t "stock", if i didn t know better......:o
Old Nov 18, 2008 | 06:09 PM
intoc6s's Avatar
intoc6s
That s kinda what i thought had happened... I just drove it around and it didn t smoke any more...but i didn t stomp it any more. I need to burn it all out and get it all cleaned out.... - Jason
Old Nov 18, 2008 | 08:32 PM
vsocks1's Avatar
vsocks1
Mine sure didn't take two days driving around to burn off....maybe the first hour at most!
Old Nov 18, 2008 | 09:13 PM
VetteHunting's Avatar
VetteHunting
New exhaust burn off doesn't take long, and is nowhere near in the amounts you describe. However, if the person you bought them from said he might have gotten some oil inside of them, dead giveaway. There is your answer. Once you started beating on it, the rear section got hot enough to burn it out.
If it was smoking at the time and you limped it home, there is probably more in there that needs burned out. Take it out and beat it on til it quits if you want.
Old Nov 18, 2008 | 11:07 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default smoke
i would believe you need a catch can if you are going to drive it hard a lot
Old Nov 18, 2008 | 11:46 PM
MLCZ51's Avatar
MLCZ51
Default I agree ......
Old Nov 19, 2008 | 01:40 AM
C5Natie's Avatar
C5Natie
Usually its the paint or coating burning off. My car smelled like a welding class the first few times with a new exhaust.
Old Nov 19, 2008 | 01:42 AM
intoc6s's Avatar
intoc6s
That s what i thought...I usually drive civil but i need to burn the oil out....
Old Nov 19, 2008 | 01:45 AM
intoc6s's Avatar
intoc6s
I put one on when i installed the new motor. Definite mod we all need...
Old Nov 19, 2008 | 03:34 AM
Cscokd's Avatar
Cscokd
new exhaust doesn't smoke like you describe. I've done 3 or 4 different exhaust systems over the years. There are two culprits that I've run into related to excess smoke....one is the mufflers or tips melting the plastic rear end at the bottom (did that at the track one day)...another is when the CV boot popped off of the axle on the passenger side throwing moly grease onto the hot exhaust pipe and I thought I had a fire under my car (did that at the Nevada Silver State Challenge this year). Get under your car and check it out carefully and don't assume anything.
Old Nov 19, 2008 | 04:03 AM
intoc6s's Avatar
intoc6s
Yeah, the guy i bought the cat-back from(black99) had got oil in both of them.....alot, aparently....and when i got the exhaust hot- Wow!!! It smoked like the motor was SHOT!! Its real cold here in Mo., and the oil didn t even get hot just driving around town, slow, like i always do. -----I really thought---"That s all it takes to blow a NEW motor up???"
Old Nov 20, 2008 | 10:58 AM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
what engine are you running and are you boosted? If you are other than stock and boosted you may have another problem...
Old Nov 20, 2008 | 02:52 PM
intoc6s's Avatar
intoc6s
Not stock(427) and in the process of Twin turbo install....I ve driven it for a couple hundred miles since that happened and its fine. Thanks -Jason
To What made my car do this??
