Removing the Front Bumper Inserts?
Old Nov 18, 2008 | 04:38 PM
Choreo's Avatar
Choreo
Default Removing the Front Bumper Inserts?
How involved is it to remove the front bumper inserts - the dull black plastic inserts that surround the fog lights on a 2001. For repair/replacement.
Old Nov 18, 2008 | 05:29 PM
dougbfresh's Avatar
dougbfresh
Take the bumper off, only takes 20 minutes. You "might" be able to reach in from the access panels underneath but it would be TIGHT.
Old Nov 22, 2008 | 01:52 PM
3whit's Avatar
3whit
Can easily be done from lower front access panel . There are four small self tapping bolts that hold them to the back of the front fasia. There is a clip that holds the wire for the side marker and that just pops out. I really would not remove the front bumper no need to .Now would be the time to install your fog lights if not equipped . I have harnesses lights and switches available .Tell your buds .Good luck with your repair
Old Nov 22, 2008 | 08:01 PM
Nick1's Avatar
Nick1
It would be wise to do a search on this. If you are handy with various projects, it will not be a problem. Otherwise it can be a real pain!
In the search you will see those who have simply cut out or drilled out holes in them. I did that originally and it came out real good. Later I installed my Vararam and now have air scoops in those locations.
Good Luck
To Removing the Front Bumper Inserts?
