AC problems - air blender??
Old Nov 20, 2008 | 04:03 PM
torchredfrc's Avatar
torchredfrc
Default AC problems - air blender??
I took the car to a mechanic to have the R134A checked and it looks like it's ok. The compressor seems to be engaging and the liquid line is getting cold. The mechanic suggested some sort of DC blender motor in the dash could be the problem. Anyone have any experience with this?
Thanks!
Old Nov 20, 2008 | 05:49 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Thanks!
Tell us about the problem/symptoms...all you told us is what's not wrong.
Old Nov 20, 2008 | 07:43 PM
torchredfrc
I apologize. The AC is blowing nothing but hot air. It seems like the air is equally warm on either side of the car. The AC was working great then just started blowing hot one night. No symptoms, sounds, etc. Any ideas?
Old Nov 20, 2008 | 09:31 PM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Default ...
check your dic for codes 1st,
your actuators may be toast,
your hvac panel may be toast
Old Nov 20, 2008 | 10:09 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Try this.
http://forums.corvetteforum.com/show....php?t=1465931
Old Nov 21, 2008 | 02:19 AM
torchredfrc
No HVAC codes. I also should have mentioned that I do not have the dual-zone controls and my manual controls are able to switch between defroster, dash, and floor. I believe this is controlled off the little vacuum line on the back of the intake.
Do vehicles w/o the dual-zone climate system have these actuators? Will the failure of these actuators always cause codes? Also, both passenger & driver side vents are blowing hot.
Old Nov 22, 2008 | 12:06 PM
torchredfrc
Ttt
To AC problems - air blender??
