Camshaft?
Old Nov 20, 2008 | 05:51 PM
jaygood's Avatar
jaygood
Default Camshaft?
Is anyone using the Texas Speed 228R camshaft (228/228-.588/.588 w/ 114 LSA.) in a A4 w/ 3:15s, if so, how do you like it?
Old Nov 20, 2008 | 07:40 PM
motogib1's Avatar
motogib1
I have a Comp 224R, 224/224 .581 lift @ 112 LSA on an A4 with 3.42 gears. It pulls just a bit on the converter so I'm thinking the 228R may be a bit much cam unless you change to a higher stall converter.
Old Nov 20, 2008 | 09:22 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Id have it on a 114 but in an mn6.
I had the TR224, pulled it and added TSP228 and AFR heads. Had nice upper RPM power, but seemed to be a little slugish on the low end. I changed the gears to 3:90s, and that fixed the low end.
Its a nice cam. Its on the upper range of medium size cams.
Old Nov 21, 2008 | 07:46 PM
verano29's Avatar
verano29
I ran the my comp cams 228/230 .571/.573 112 on my A4 w/ 2.73s for a couple of weeks before I swapped the rear and converter. It was hard to keep it running at a stop light but if I would have raised the idle a bit it would have been fine.
To Camshaft?
