Now that I have had time to think about your problem, I'm afraid it is much more serious than I first thought.
I'm afraid that there is nothing you can do to fix your car now that the tire pressure is so low. I would take this problem car off of your hands without any payment from you. Please PM me with your address immediately.
Right Front is showing 22 PSI, rest of the car is 30PSI.
It raises while driving 1 pound after awhile.
Should I just add air to the tire? Someone please lend the assist .
So I understand this correctly. Three out of four wheels are displaying 30 psi, and one wheel is displaying 22 psi. So the TPS is telling you that one tire is low on air, and you want to know if you should add air to it.
My suggestion, is that you take your car to a qualified mechanic to have the tire pressure checked. Most qualified mechanics have a device called a "tire pressure gauge". This device is used to ascertain the air pressure in each individual tire. After evaluating the air pressure in each tire, the mechanic can then decide what the best course of action is.
If you add air and it still decreases soon with no obvious nails, etc., be sure to check the valve stem nut. It should be bette than "snug" but not too tight.
Although you can't rotate the tires on a C5 (due to size and directional characteristics), you should rotate the air in your tires. Have you been doing this? If not, you probably ruined one of your tire's seals.
To the OP, now that you've had your flame suit cooked a bit, did you resolve the issue? BTW, we've all had our moments here on the forum so believe me, you aren't alone. If you truly have a bad TPS, the batteries in them supposedly last about 8-10 years and there is a place that can rebuild them but their website is full of spybots, so I won't post it here. Most people just buy new ones.
