CAM Only
Old Nov 24, 2008 | 11:01 AM
SargeZ06's Avatar
SargeZ06
Default CAM Only
What CAM only packages are netting the best numbers on stock LS1s with Headers and CAI?
No fly-cutting...
I likes'em choppy...
Old Nov 24, 2008 | 11:44 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
I have a LG G5X3/114 cam in my 01 Z06. Making 420 rwhp.
You might want to look into some LS6 heads or ported LS1 heads if you go to a bigger cam. The stock LS1 heads are going to limit your gains.
Old Nov 24, 2008 | 11:47 AM
black98c5's Avatar
black98c5
G3X3 112 LSA - on my A4 with 3:73's and 3600 stall- 380rwhp on a Mustang Dyno which is said to be 400+rwhp on a Dynojet. Oh, and that was with crappy 853 heads (untouched) and a LS1 intake manifold.
Old Nov 24, 2008 | 11:50 AM
SargeZ06's Avatar
SargeZ06
Thanks Independent1.
Heads are definately on the list but I thought the CAM would get me the biggest gain right now.
So no fly-cutting with the G5X3? Just 7.4 rods and good springs would be all I need with this cam?
Also this car is an A4 (RPM Level IV)
Old Nov 24, 2008 | 11:52 AM
SargeZ06's Avatar
SargeZ06
Is that with Headers or stock manifolds?
Old Nov 24, 2008 | 11:56 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
There are a few top end cams that net big power with stock heads: TREX, Vindicator, MS4, Polluter, and etc. check them all out.
dixonk's Avatar
dixonk
St. Jude Donor '09
Better to get a custom grind though.
Old Nov 24, 2008 | 11:59 AM
black98c5's Avatar
black98c5
Dynatech LT's (no cats)- Callaway Honker CAI-SLP Underdrive pulley-Corsa Indy's.
Old Nov 24, 2008 | 12:15 PM
ROJO99's Avatar
ROJO99
Whiplash (EnglandGreen, Gulf coast Perf) netted, 402RWHP on a Dyno Dynamics Dyno. May be more but I am out of injector.
Old Nov 24, 2008 | 02:49 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Here's our NA cam.... (same as the one in my car) on a stock headed LS1...
Made a touch more on an LS6. The car had headers and an intake on it as well....
Old Nov 24, 2008 | 03:36 PM
Numb's Avatar
Numb
LG G6X3-V2 cam, stock LS6 heads milled to 59cc, LG pro longtubes, vararam: 440whp/406wtq. I did flycut my pistons, though... don't be skeered.
Old Nov 24, 2008 | 03:46 PM
black98c5's Avatar
black98c5
That's awesome power you're making.
Old Nov 24, 2008 | 03:48 PM
SargeZ06's Avatar
SargeZ06
That's krazy numbers.
Ha yeah I would be skeer'd too. I'd rather pull the pistons and cut'em and weigh them. But if I wanted to do that I would just do a whole new forged build...
Just looking for simplicity and stability.
Old Nov 24, 2008 | 04:10 PM
LDB C5's Avatar
LDB C5
What are the cam specs? Those seem like pretty good numbers.
Old Nov 24, 2008 | 05:44 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
To be quite honest I don't know... Only Chris and Doug hold that info...
but I can say it's in the ball park of 230s and under 600 Lift. It's not insane and no need to flycut.
Here is a vid of it on my Z (with trick flow 215's and some other mods).
Old Nov 25, 2008 | 10:59 AM
Independent1
St. Jude Donor '08
^^Sorry it took me so long to get back. No fly-cutting with the 114. You don't want to fly cut the stock pistons. There is not much to them as it is.
I agree with you that cam is the biggest gain. I only mentioned the heads to save you $$ in the long-run so you don't have to get it tuned twice. You can pick-up some nice heads for about $500 that you can just bolt on.
Old Jan 7, 2009 | 08:12 PM
SargeZ06's Avatar
SargeZ06
Okay so I got a Whiplash CAM.
Now I see that some packages include:
LS2 Timing cover
LS2 Timing Chain
Under Drive Pulley
My question is what are the benefit of each of these. From what I understand the under drive pulley will only net about 5 RWHP.
Do I still have to pin the stock pulley if I reuse it?
Steve
Old Jan 7, 2009 | 08:45 PM
DAYUIZ's Avatar
DAYUIZ
Old Jan 7, 2009 | 11:07 PM
T.J.'s Avatar
T.J.
Don't reuse your stock pulley because it will wobble and then you'll have to put your UDP on later. Save yourself the trouble and do it now.
To CAM Only
