Speedometer is crazy
Old Nov 25, 2008 | 09:37 PM
Biggreen99's Avatar
Biggreen99
Default Speedometer is crazy
Today my speedometer started switching from mph to km/hour on it's own. I was going 70 on the freeway, then instantly 115 . Freaked me out till I realized it switched units of measure. It proceeded to switch back & forth seemingly at random. Anyone have an idea what would cause this? When it went to the metric reading, I hit the E/M button on the DIC and it went back to mph. However, it would continue switching back & forth again all by itself shortly thereafter. I tried the reset button too but it didn't stop the speedo from changing from mph to km/hour on it's own. Any ideas why my speedometer is doing this?
Old Nov 25, 2008 | 09:58 PM
Bill Dearborn's Avatar
Bill Dearborn
Weird electronic behavior can usually be traced to a voltage or ground problem.
Bill
Old Nov 26, 2008 | 11:56 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check for a shorting wire in the door accordian tube that finds its way to the frame.
Old Nov 26, 2008 | 04:44 PM
Biggreen99's Avatar
Biggreen99
I'll check for loose wires. Thanks for the suggestion about the door neighbor.
Old Nov 28, 2008 | 03:56 PM
dgrant3830's Avatar
dgrant3830
Since you are right here somewhere, I can help you out if you need. Just send me a PM to where you live. I'm across from Victoria Gardens.
To Speedometer is crazy
