Crank Position Sensor Relearn
Old Nov 26, 2008 | 12:37 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Default Crank Position Sensor Relearn
Hey guys/gals, I just replaced my clutch (on my 2000) and now the car runs like crap, it pops and shoots flames out the exhaust. The Snap-On scanner tool that our shop has reads a DTC P1366 code and I was wondering if I can reset it without towing it to a Chev dealership.
TIA.
Old Nov 26, 2008 | 12:46 AM
lucky131969's Avatar
lucky131969
TIA.
Ok, you got me. What is a P1366. I do not even show that as a valid DTC code for a 2000.
Old Nov 26, 2008 | 12:51 AM
lucky131969
Ok, you must mean P1336. Even so, that code was not applicable for 2000. It started in 2001. Maybe you got an early PCM? Anyway, can you verify the code through the DTC and not the scanner?
I would start by inspecting the connector and wiring going to the CKP to see if it was disturbed or damaged in the course of your work.
Old Nov 26, 2008 | 01:02 AM
themonk's Avatar
themonk
I'll ask my tech again, I could be wrong (like that's never happened.)
Yeah, I just checked Mitchell On Demand, it is P1336. I'll check the DIC tomorrow and see what I come up with.
A little history on my car though. It is a flood salvage from Indiana so the PCM could've been changed but even so it would've had to have been nothing newer than a 2000.
Old Nov 26, 2008 | 01:08 AM
lucky131969
Like I said, start with a physical inspection of the CKP wiring and connector for damage, etc. Especially since the car was just worked on. I take it the car was in running condition before the clutch change.
Old Nov 26, 2008 | 02:43 PM
themonk's Avatar
themonk
Yeah it was fine before the clutch replace.
Old Dec 3, 2009 | 01:50 AM
vette_c5's Avatar
vette_c5
1st Gear
Default Cranksahft Position Sensor Relearn
Did you ever figure out the crank sensor problem?
I've got the same problem on my C5.
DTC indicates crankshaft position sensor performance problem.
Runs crappy. Won't really rev. Pops out exhaust.
Resetting code doesn't solve it.
Did you have to do a relearn?
Was it a wiring problem?
Old Jan 4, 2016 | 12:53 AM
96TTdodge's Avatar
96TTdodge
TIA.
Bringing this thread way back from the dead. Can you tell me how this was ever resolved please? You and vette_c5 have the same symptoms as I do.
Thank you!
Old Jan 4, 2016 | 06:32 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I just ran in to this issue after replacing the PCM in my sisters Trailblazer. I used a Tech 2 clone to relearn the crank sensor !!!!!
To Crank Position Sensor Relearn
