Ford 9 inch swap help
Old Nov 26, 2008 | 08:41 PM
Roger Z06's Avatar
Roger Z06
Default Ford 9 inch swap help
I am trying to build a drag c5 coupe. I think I am going to swap the IRS for a Ford 9 inch and want to know if anyone has done this before that could give me some pointers. Is there any kits to help you do it like brackets or do you need anything custom. Any help is good, Thanks Roger.
Old Nov 26, 2008 | 10:01 PM
happa's Avatar
happa
Not sure if someone will answer in here. Try Drag racing section.
Good Luck on your build!
Old Nov 26, 2008 | 10:05 PM
4DRUSH's Avatar
4DRUSH
Carrols Rod & Racecraft will have a C5 kit soon
http://www.rodandracecraft.com/
Old Nov 26, 2008 | 11:09 PM
slowtealz28's Avatar
slowtealz28
4D, what rear do you have in your car? The 9" will be badass, but bye bye handling.
Old Nov 26, 2008 | 11:13 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
There are a couple of home done solid axle swaps over in the Corvette section of LS1Tech
Old Nov 27, 2008 | 12:48 AM
4DRUSH's Avatar
4DRUSH
I have a C5 3:42 rear build by RPM. Over 200 9 sec passes and never had a problem with it.
Old Nov 28, 2008 | 03:48 PM
Roger Z06's Avatar
Roger Z06
I have the Stock IRS, but I figured the 9 inch would hook/be more reliable. I am not making a stupid drag car, but I am thinking Nitrous Cam, 150 Shot, And a Turbo 400 with a transbrake. Is there a way that I can bolt a Turbo 400 up to the IRS?
Old Nov 28, 2008 | 07:12 PM
tiojames's Avatar
tiojames
I think ECS has done some work with the Ford 9". You might contact them.
Old Nov 28, 2008 | 07:43 PM
clemsondave's Avatar
clemsondave
Yes. There are even a few 4l80's out there.
To Ford 9 inch swap help
