05 C6 manual into a C5
Old Nov 28, 2008 | 10:31 PM
vettesrgt8's Avatar
vettesrgt8
Default 05 C6 manual into a C5
I've searched and can't find an answer to this question. Will a 2005 C6 manual tranny fit into a C5 with little or no modification? I'm sure I'm just not looking properly. A link is fine. Or a discourse. Thanks
Last edited by vettesrgt8; Nov 28, 2008 at 10:32 PM. Reason: added instant email notification
Old Nov 29, 2008 | 12:05 AM
vettesrgt8's Avatar
vettesrgt8
Nobody.
Old Nov 29, 2008 | 09:43 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Fartpipe did it
I do not have firsthand experience
Old Nov 29, 2008 | 12:42 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Yes, it is a direct bolt in as long as the 05 it came out of was not Z51 equipped. The 05 tranny has a better centering mechanism too. 06+ will not work, Z51 or not.
Old Dec 1, 2008 | 12:50 PM
vettesrgt8's Avatar
vettesrgt8
Thanks. Fartpipe called me and told me the same. I don't remember it well enough for someone to take this as gospel ok but you have to move a sensor on the 05 tranny. On 06 and up they require more work but apparently it's not too complicated. As least not for Fartpipe. He's a great guy by the way. Not nearly as gassy as you'd think.
Old Dec 1, 2008 | 06:05 PM
Mike94ZLT1's Avatar
Mike94ZLT1
On a 2006 and up you need to change the tailhousing and output shaft, or change your rear diff to a c6 style along with the rear k member and lower control arms. Either way will work, and there are a few wiring changes you need to make. Not rocket science, but it definitely isn't something for a novice.
To 05 C6 manual into a C5
