Help please Header install now stearing loose
TIA Darrin.
Here are the GM instructions for putting it back together.
- Place the intermediate shaft into vehicle.
- Slide the upper coupling into the steering column shaft.
- Connect the lower coupling onto the steering gear. Notice
Refer to Fastener Notice in Cautions and Notices. - Install the lower coupling retaining bolt into the lower coupling. Tighten Tighten the lower coupling retaining bolt to 34 N·m (25 lb ft).
- Remove J 42640 from the steering column.
- Unlock the steering column.
- Turn the steering wheel far enough to the left to gain access to the upper coupling bolt hole.
- Install the upper coupling bolt into the upper coupling. Tighten Tighten the upper coupling bolt to 48 N·m (35 lb ft).
- Turn the steering wheel back to the right until the wheels are in a straight ahead position, then lock the steering column.
- Install the lower steering coupling shield. Tighten Tighten the lower steering coupling shield screw to 3.5 N·m (31 lb in).
