Console Lubrication?
Old Dec 6, 2008 | 01:29 PM
IAIA's Avatar
IAIA
Default Console Lubrication?
Not really a "tech" question, but I figured you guys would know.
I took off the center console to fix the lighter socket, which unscrewed. Before putting it all back, I wanted to lubricate some of the touch points where you get creaks and squeaks....
What should I use? I was thinking a microthin layer of silicone grease, but that stuff is supposed to dry out vinyl moulding?
Any help?
Thanks in advance.
Old Dec 6, 2008 | 02:19 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
About you need to do is the hinge......a drop of any light oil will do 9there are about 6 or so different points you can do on that hinge) I used Marvel Mystery Oil
Old Dec 6, 2008 | 04:29 PM
Choreo's Avatar
Choreo
I used graphite (sparingly).
Old Dec 6, 2008 | 04:50 PM
lucky131969's Avatar
lucky131969
I used a little bacon grease applied with a Q-tip.
Old Dec 6, 2008 | 06:46 PM
IAIA's Avatar
IAIA
Thanks. I should've also said around the trim/faceplate panel around the radio/AC where the cigarette lighter is. Mine squeaks in there, too.
Bacon grease, huh?
Old Dec 6, 2008 | 08:54 PM
coxjajb's Avatar
coxjajb
Lucky, Bacon Grease? Do dogs chase your car?
To Console Lubrication?
