which headers are better?
Old Dec 8, 2008 | 08:03 PM
ncevette's Avatar
ncevette
Default which headers are better?
what headers are bette shorty or long ones?
Old Dec 8, 2008 | 08:06 PM
lucky131969's Avatar
lucky131969
lots of reading on this..doe a search for "shorty headers"
Old Dec 8, 2008 | 08:07 PM
motogib1's Avatar
motogib1
The general consensus around the forum seems to be that long tube headers out perform the shorties. I know from personal experience that the long tubes are a good bang for the buck performance enhancer.
Old Dec 8, 2008 | 08:50 PM
C5SCCA's Avatar
C5SCCA
Shorty headers vs. long tubes? There is no comparison.
Old Dec 8, 2008 | 08:53 PM
aleadfoot's Avatar
aleadfoot
The stock exhaust manifolds are as good as the shorties. Save up and put the long tubes on if you got the hankerin. I did and if I was to do over I'd leave it stock. Mod fever passes but man it can be intense. Shorties aint worth the trouble of install let alone the money. Best of Luck
Old Dec 9, 2008 | 10:08 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
We only install long tube headers.
Old Dec 9, 2008 | 12:44 PM
hotwheels57's Avatar
hotwheels57
Where do you live? Do you live in a state that requires annual emissions inspections?
Read you state statutes about exhaust system requirements.
The shorty headers are generally favored because they're 50 state CARB legal, can be installed by the owner w/o great difficulty, mount up to and don't require any other changes to the exhaust system, remove weight off the front end, are usually less expensive and don't require a tune.
You may only achieve 10hp with shorty headers. Long tube headers may achieve more but come with caveats.
Old Dec 9, 2008 | 12:59 PM
50th@50's Avatar
50th@50
You know Hotwheels57, seems only you and I defend short tubes.
Don`t forget dropping about 20 lbs. off you engine block also, not to mention the sweet looks over rusted OEM manifolds!
Me, 03. A4 3.15, twin cone, (poo-poo they say), Flowmasters (poop again), and BB shortys (whata waste), Charlie at RPM tuned me to 331 RWHP and , get this, 347 RWtorque. I quess I have a freak car then cause those numbers match or exceed the long tubes and X pipes and real CAI, etc. etc., wonder where all that torque is coming from anyway??????
CARB legal with an EO number supplied regarding the BB shortys. The only issue I see is these particular ones are VERY expensive, maybe shop used?
Old Dec 9, 2008 | 01:07 PM
hotwheels57
There's more than just you and I...and many of those who elect to use them have documented dyno evidence as well.
They'll be my choice soon for the reasons I enumerated. I don't have emissions requirements in my county...YET...but, it's only a matter of time. I like them mainly for the weight off the front as we both mentioned.
Most just don't want to get into the never ending debate...
Old Dec 9, 2008 | 01:16 PM
50th@50's Avatar
50th@50
Hey HW57, someone said your Jay Leno, hiding I quess, since I`m just south of you in Torrance can I come up to your garage and check some of your rides out please? BTW, Letterman sucks!
Old Dec 9, 2008 | 02:15 PM
guitar420911's Avatar
guitar420911
No real comparison between the two long tubes should net you much better results.
BTW I thought Jay Leno had a 02 yellow Z06 with an LS7.
Old Dec 9, 2008 | 02:58 PM
leadfoot_mf's Avatar
leadfoot_mf
yeah jay only has one corvette.
Old Dec 9, 2008 | 04:15 PM
50th@50's Avatar
50th@50
AND a new ZR1 to throw into the pile of his "toys". He is truly a car nut who can drive em just as well as most any.
No doubt, LT by far trump the shortys for HP, but they are NOT worthless as people like to say. Torque I think is better in mid range with shortys and higher end power with LT`s, I forget, but anyway, if anyone who is concerned about emission laws wants a nice up grade I would not hesitate to recommend good QUALITY shortys such as Billy Boat, but again,I do feel a litttle quilty they cost a fortune compared to a complete LT exhaust package. Frankly mine cost 1,200 including having them jet coated. A friend and I installed em thankfully. So if you can, by a good used set maybe. Again with my chincy mods how do you explain SAE corrected Dynojet at 347 RWtorque, very high for my lightweight mods, IMO.
Chow huh,
Old Dec 9, 2008 | 06:06 PM
Roger Z06's Avatar
Roger Z06
kooks ftw
Old Dec 12, 2008 | 06:16 PM
96mogt's Avatar
96mogt
High torque ='s converter spike on the dyno JK. Nice numbers for a A4. I went with American Racing 1 7\8 Long tubes.
Old Aug 23, 2021 | 08:15 PM
LTCHAPPA's Avatar
LTCHAPPA
Long tube headers Black Wing, cat back Dyno tune 354 at the wheels
Old Mar 4, 2024 | 02:22 AM
sirdano's Avatar
sirdano
anyone do a compair of stock vs z06. Visually?
To which headers are better?
Old Mar 4, 2024 | 09:36 AM
Prop Joe's Avatar
Prop Joe
Better or Cheaper? Kooks and American Racing are the best that I have seen and the LG's are said to be good.
Cheapish, Chineasium and easy to install is SE:
https://speed-engineering.com/collec...s1-ls6-engines
I put Jet Hot Coated SE on my Corvette after speaking to many people about the quality and fit of the SE headers.. They went in easy, with nice fit/clearance in the engine bay and good ground clearance. If money was no object I'd do the American Racing headers + Jet Hot, as I have a set on the Oldsmobile I used to race. Those Olds headers were $600-650 for the Olds when they were 1st offered for the 86 gbody SBO Olds around 2007. At the time you get cheap Flowmasters for less than $200 on the Olds. $2k for the Corvette plus the Jet Hot was a little steep at the time when I was purchasing all the other parts for the Head/Cam/ Header swap I did last spring. No regrets.
Old Mar 4, 2024 | 01:33 PM
Tron Z's Avatar
Tron Z
Better for what?
Shorties are cheaper, easier to install and some of them carry an emissions compliance certification. They offer a modest power increase at best.
Long tubes are more expensive, more difficult to install and are illegal in all 50 states. They offer a more significant power increase at very high RPMs.
Old Mar 6, 2024 | 05:01 AM
johndavid10's Avatar
johndavid10
2nd Gear
internet
