18" Steetable slicks?
Old Jan 16, 2002 | 10:49 PM
elitedc's Avatar
elitedc
Default 18" slicks?
18" slicks? Is there such a thing. maybe Nitto? Now im using nitto's on 17" rims? This is probably an age old question.
Thank you
[Modified by elitedc, 6:27 PM 1/17/2002]
[Modified by elitedc, 6:28 PM 1/17/2002]
Old Jan 17, 2002 | 12:37 AM
davidfarmer's Avatar
davidfarmer
Default Re: 18" Steetable slicks? (elitedc)
Your best bet would probably be a 335 Hoosier autocross tire. Tire rack has them. Although they are technical "treaded", they are very soft and have almost a slick surface.
Old Jan 17, 2002 | 07:22 PM
TOPGUN9's Avatar
TOPGUN9
Y2K is on the right track. Before I went to slicks, I ran McCreary road racing tires that were treaded (with tubes) on my 428SCJ Mach I. Very soft compound tires. I wouldn't recommend slicks for the street. They have very thin sidewalls.
Old Jan 17, 2002 | 07:34 PM
MitchellDavidson's Avatar
MitchellDavidson
Default Re: 18" Steetable slicks? (y2khardtop)
How many miles could you expect with Hoosier's under normal driving? How much do a rear pair cost? :D
Old Jan 17, 2002 | 08:23 PM
LANJET's Avatar
LANJET
Default Re: 18" Steetable slicks? (MitchellDavidson)
I tried a pair of Goodyear roadrace slicks on a ZR-1 at the drag strip one time, and they were terrible. The sidewalls are so stiff on roadrace slicks that there is no "wrinkle". I put the stock GSC's back on and the traction was much better. The compound/sidewall may be different on the DOT tires? Just my experience. If I were going to drag race I would go with a tire designed specifically for that purpose.
LPE TT650
Old Jan 17, 2002 | 09:11 PM
vstella's Avatar
vstella
Default Re: 18" slicks? (elitedc)
Yes! Nitto 555R Drag radials are available from www.discounttire.com:DThey're only available in size 305x45x18......$225 each+shipping or Call them at 800-739-8999 ask for Brad!
I haven't bought them yet as I understand it's a tall DR at 28.8 inches.I don't know how I'm going to fit it on the car since my car is lowered to 27.25 all around...but I will.The Nitto 555 street tires are really not bad for the track.I have had good luck with them for a street tire.:D
Old Jan 17, 2002 | 10:03 PM
MitchellDavidson
Default Re: 18" Steetable slicks? (LANJET)
LANJET, are you saying Hoosier's make poor drag racing tires? Even worse than runcraps?? :eek:
Old Jan 17, 2002 | 11:06 PM
LANJET's Avatar
LANJET
Hey, I don't know about Hoosier's, but the Goodyear slicks were like driving on ice!!!!! So the runcraps are pretty bad huh?
LPE TT650
Old Jan 17, 2002 | 11:27 PM
MelloYellow's Avatar
MelloYellow
Someone was running a PZero race series (barely) street tire that was 'sposed to be very good. Hmm..
To 18" Steetable slicks?
