Okay let me start by giving a little history on my Vette.
About a year ago I was rearended in traffic. The damage was severe enough to send the car to the frame shop. The entire rear compartment was replaced as was the top roof bow.
Now with that said....
It's been a while since I gotten on the car really hard other than punching it on the highway. Yesterday I came around under a highway intersection, nailed it from second gear to beat the oncoming traffic.
Took the revs up to about 4K and went to shift into 3rd. When I got out of the gas to shift the cars nose started to come down and the car then slightly pulled to the right ! And it did it again from 3rd to 4th shift...
Did the shop not do a good job on the frame repair or are my tire alignments off ??
Did the shop straighten the frame or replace a section of the frame? The car is not a unibody car and the frame is separate from the body so replacement of the compartment doesn't neccesarily mean the frame was severely damaged.
I would suspect a loose component in the rear like a tie rod or control arm bushing which is causing a toe-in change under hard acceleration.
Have the wheel alignment checked again. A good alignment shop can quickly determine if the frame is straight or not. I'm assuming that your tire inflation pressures are correct.
Bill
I do realize that. Although the frame was damaged as the rear suspension was shifted forward about 1" difference from the drivers side. The gap in front of the passenger tire to the fender wheel well was less than the drivers side.
I'll have a shop look at the rear suspension components.
I'll be taking it in for a checkup on the alignment. I had this done a few months back and it carries a life time guarantee.
