Replacing Front Wheel Hub/bearings
1. do torque measurements have to be exact? or are they the minimum required?
2. will i need loctite?
any helpfull info will be greatly appreciated.
TIA
TIA
I would recommend using either acetone or fingernail polish remover (contains acetone) and a wire brush to remove any old thread locker from the mounting bolts and the bolts holes. Then use a couple of drops of red Loc-Tite.
HTH
Breaking the lower ball joint without the pickle fork is a little tough. I have a heavy lead hammer that I use for the spinners on my wire wheels on an old Jaguar. After beating the wood block for 10 minutes and getting nowhere, I got the lead hammer out, and hit the front lip of the lower A-arm a couple of times, and the ball joint came right out of the spindle. Same on the other side.
When you put the bolts back in to the upright to secure the bearing unit, you must use red Loctite. The torque figures he give (96 ft.lbs. for the bearing bolts IIRC) is what you need to torque to. Don't over-torque them, as you don't want to stretch them and lose strength.
Other than that, it's a very straightforward job. Just read through that write-up and you'll see how it works. Best of luck with it.
BTW, I installed the SKF racing bearings. And excellent product. I got them from Pfadt. They are about twice the cost of the Timken bearings, but in street use, should last for just about ever. For track use, they should last a whole season or longer, vs. a few events for the Timkens.
BTW, that was FasterIsBetter that installed the Pfadt bearings not me. I'm just a big fan. He said he got them from Pfadt and are about twice the price of Timkens (which I'm running now). That would put them somewhere between $300 and $400 EACH.
HTH
Bill
HTH
BTW, I try to remember to paste my threads with copper before remounting wheels and tires. I know that is another metal to react with things touching it but it seems to work for me and I get no problems with stuck lugs and broken studs.
http://www.amazon.com/Loctite-Copper.../dp/B0006Q7H36
http://www.sealingdevices.com/loctite/c5a.html
HTH,
Tex_Vette
HTH,
Tex_Vette
It works is all I can say. Esp good when on trailers and even better on them that are exposed to saltwater. Also great for racers as the high temps don't fuse the aluminum lugs to the threads. Most of the time the threads separate but occasionally you end up breaking the stud trying to get the lugs off if you don't use some sort of anti-seize to clear that up.
How much does it throw it off, BTW?
"Unless specifically stated otherwise, wheel lug torque specifications are for clean and dry threads (no lubricant) that are free of dirt, grit, etc. Applying oil, grease or anti-seize lubricants to the threads will result in inaccurate torque values that over tighten the wheels."
That is quote from Tire Rack's website, but the same info can be found in many other places, especily from many manufacturers.
bh
bh
Seriously, torquing is a good idea for the benefit of the wheels, rotors, and peace of mind.
