vin #
Old Dec 13, 2008 | 10:03 AM
cobra3's Avatar
cobra3
Default vin #
Ok , I have a qustion that I should know the answer to but I dont.
How do you tell by looking at the vin. # what your vette has as far as susp. and other things. I have had my vette for about two years have just never really thought much about it untill I got on hear .I am thinking about doing some more to the car , it has a Corsa cat back and a CAI and a tune . I would just like to know a little more about the car itself though .I know its a dumb question but any help would be thankful.
Old Dec 13, 2008 | 10:31 AM
fixvet's Avatar
fixvet
Nope, there's nothing about options etc. in the vin #. Basically it's a production serial number. There are alot of websites that explain it if you do a google search.
Old Dec 13, 2008 | 12:16 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
The VIN itself does not have that information but can be used to find it out.
The Corvette Museum sells copies of the window stickers and build sheet that go with the car based on the VIN.
There also should be an options list inside the glove box door that gives you all the RPO codes for the car.
Old Dec 13, 2008 | 03:29 PM
El Zappo's Avatar
El Zappo
From: Remember the average response time to a 911 call is over 6 minutes. The average response time of a .357 magnum is 1400 fps.
PM Sponge Vette, or email Gene Culley @ GMPartshouse and ask for a GM-VIS. Give them your Vin and they will give you the info you seek, and a lot of other good info.
Old Dec 14, 2008 | 05:22 AM
dieseldave56's Avatar
dieseldave56
Default glove box door
The glove box door has the list of options http://www.c5registry.com/membersonl...suspension.htm
Old Dec 14, 2008 | 09:01 AM
cobra3's Avatar
cobra3
Default vin#
Hey guys thanks for all in info , maybe now I can figure out what I have . This is my first vette. and just want to know what I have , the car has some mods on it but I wanted to know the stock specs. also.
Old Dec 14, 2008 | 10:58 AM
65GGvert's Avatar
65GGvert
Fill out your profile so we'll know what year your car is. The options list is not on the glove box lids on the earlier model C5's. It's on the rear driver's side compartment cover. At least when you ask a question, mention the year and body style Vette you have. Otherwise, you may get an answer that doesn't match up to your car.
For example, they don't all use the same key fobs, they don't all come with the same wheels, they haven't different antennas, etc.
To vin #
